Possible to measure distances in a photo?
  • Possible to measure distances in a photo?
    Typically I'm doing modeling from cad, elevations, etc with dimensions. In this case I need to build a space in 3d from photos. Is there a way to measure a distance if you don't know a single measurement? I know this sounds like a rookie question from someone who's done archviz for a while, but I've honestly never had the need (or I've always had the dimensions).
    Attached is an example of what I'm working with. Thanks in advance...
    If you know one dimension you can use SketchUp.
    https://www.google.com/search?q=get+...hrome&ie=UTF-8
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      Assume the seat cushions are 425-450mm off the floor. from that you can figure out the height of the wood trim / ceiling, wall width etc.
