I'm animating a camera and can't figure out how to animate the "focus distance" parameter. The values just won't stick, but default back to the initial keyframe. Is this not possible?!?
Keyframe focus distance?
David Anderson
www.DavidAnderson.tv
Software:
Windows 10 Pro
3ds Max 2023.3 Update
V-Ray GPU 6 Update 1
Hardware:
Puget Systems TRX40 EATX
AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
2X NVIDIA GeForce RTX 3090
128GB RAMTags: None
Originally posted by Streetwise View PostI'm animating a camera and can't figure out how to animate the "focus distance" parameter. The values just won't stick, but default back to the initial keyframe. Is this not possible?!?
With max's physical cam it works fine it seems
EDIT:
Hmmm weird, I updated Next to 1.1, now the Max cam behaves same as the VRaycam and both dont work....Last edited by Morne; 27-12-2018, 03:18 AM.Kind Regards,
Morne
That's interesting. It is an older V-Ray camera that's not working, so I tried a new VRayPhysicalCamera and same thing happens. But you're saying it is possible to key the focus distance, in theory?David Anderson
Software:
Windows 10 Pro
Hardware:
128GB RAM
