Chromatic aberration before glare or afterwards?
  • Chromatic aberration before glare or afterwards?
    This is a compositing question.
    Whats the right order?
    In real world photos, is CA on the glare or is the glare on top?
    And if the first is right: Should I make the glare respect the CA? Or should I generate it from the raw image and add it to the CA'ed image?
    German guy, sorry for my English.
    Good question; let me ask Asen and see if he has any thoughts.
      Here is the answer I got:
      I think first chromatic aberration, because the light first passes through the lens (which causes CA) and then through the aperture (which causes most of the lens glare).
      However because we don't have chromatic aberration built-in, there is no easy way to do that; you'll have to save the raw image, apply the CA, then load it back in the VFB to apply the glare. I guess this is where having built-in CA would be useful.
      It would be interesting to actually make an experiment and see if there is a huge difference if you apply CA first and then the glare on top of it, or vice versa.
        However, because we don't have chromatic aberration built-in, there is no easy way to do that; you'll have to save the raw image, apply the CA, then load it back in the VFB to apply the glare. I guess this is where having built-in CA would be useful.
        Thank you!
        Right now I'm taking the output from fusion into max and use it as an environment in screen mode. That works quite well and I can render it through backburner.
        It's good to know, even when I don't have the time for the extra pass and use fusion's clunky tools for generating glare!
        If we'd only could get the vray lens effects along with the denoiser into fusion. But they don't have a sdk if I remember correctly.
        I think it might change the color of the glare a bit.
        I'll see if I can find a scene which I can show to test it.
          First a quick test under laboratory conditions.
          All have the same settings for glare (default but 2 for intensity)
          Vray glare without CA:
          Click image for larger version  Name:	VrayGlare.jpg Views:	1 Size:	255.1 KB ID:	1022216
          With CA before glare:
          Vray glare with CA Type 1:
          Click image for larger version  Name:	Glare_CA1.jpg Views:	1 Size:	255.8 KB ID:	1022214
          Vray glare with CA Type 2 in very aggressive settings:
          Click image for larger version  Name:	Glare_CA2_1.jpg Views:	1 Size:	276.4 KB ID:	1022215
          Vray glare with CA Type 2 in modest settings (as I use it most of the times.):
          Click image for larger version  Name:	Glare_CA2_2.jpg Views:	1 Size:	258.7 KB ID:	1022217
          If anyone is interested:
          The CA Type 1 is from https://gumroad.com/l/NJTC
          The CA Type 2 is from the MT Glitch package which is free and available through reactor https://www.steakunderwater.com/wesu...amp;amp;t=1775.
            With glare before CA:
            Click image for larger version  Name:	aCA1_0000.jpg Views:	1 Size:	332.9 KB ID:	1022219
            Vray glare with CA Type 2 aggressive:
            Click image for larger version  Name:	aCA2_1_0000.jpg Views:	1 Size:	387.7 KB ID:	1022220
            Vray glare with CA Type 2 modest:
            Click image for larger version  Name:	aCA2_2_0000.jpg Views:	1 Size:	368.1 KB ID:	1022221
            To me the CA-before-glare Images are looking way more realistic.
            I'll test it in a production scene later, the difference will be less obvious I think.
