Forest Pack Pro Scale
  • Forest Pack Pro Scale
    I have a scene that started off in CM and I converted to inches. I reset things (xform), but my Forest grass and gravel will not scale. I exported as a dwg and imported, but nothing seems to be working. HELP!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Pick the objects again after you've collapsed the xforms or maybe use the global scale to convert between cm and inch? It's a factor of about 2.54 I think?
      I tried the world scale, but it scaled the actual geometry.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        You can just use global scale of the objects in the FP. https://dl.dropboxusercontent.com/s/...312_094613.png
        Available for remote work.
        My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
          You never change scene scale. Instead, make a new scene with the units you need, then merge the objects from the other scene into it. Things will magically be correct. This works for most things, except BIPED, Particles, Hair & Fur, and things that use real world physics like cloth sim fror example.
          Kind Regards,
          Morne
            Yes, but things don't fill out properly doing that.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I tried that. Something strange is going on.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                It is a freaking mess! I scale the scene and my windows go out in space. This has messed me up before and it takes rebuilding things, but this scene is complicated.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  There has to be a solution to this. It seems only Forest is having issues. I have scaled in every way I know how to. Forest is reading the grass as millimeters and the gravel in centimeters, but MAX is showing it 100% scale. Any ideas? I have posted this over on the Forest forum, too.
                  https://files.acrobat.com/a/preview/...c-d07ee62e4f81
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    I'd persevere with merging into a new scene to change the units.
                    Win10 x64, 3DS Max 2017 19.0, Vray 3.60.03
                    Threadripper 1950x, 64GB RAM, Aurous Gaming 7 x399,
                      To me this seems to look correct.
                        Did you do anything to it to make it work?
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          That usually works, but not in this case. I have a few ideas to try today.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            He opened it in Germany, where they have metric units. ^^
                            Lele
                            emanuele.lecchi@chaos.com
                            Disclaimer:
                            • #15
                              In Germany we have the best of all metric units
                              No, I just opened it, used your inches scaling and reset all the scale values of the Forest Pack objects (global scale etc. to 100%). I could upload the scene, but it should work that way on your end as well.
