Blue Screen
  • Blue Screen
    I have a computer which goes to blue screen. DELL can't figure it out, without swapping parts, which is a slow way to troubleshoot. I updated the BIOS, launched Windows and it went to bluescreen. They replaced the motherboard, but still bluescreen. Next, they'll be replacing the hard drive. It usually crashes when running a plugin while in Photoshop, but it isn't always the same script. It also crashed doing something else outside of Photoshop.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Whats the message on the bluescreen?
    it usually gives a HEX error code
    Some thoughts, did you recently update to Windows version 1903 up from version 1809? That could be the culprit
    Or do a windows memory diagnostic check (you can find it Windows Administrative Tools). It will restart your system and with default, it runs a basic check. You can also do a medium or advanced check.
    Let the medium one run overnight and see if it reports erros after it automatically restarts when its done. Dont do the advanced one, as with 128GB like you have, it will take forever
    You can also physically take out half your ram and see how it goes. Then you could take the 2nd half out and put back the 1st half etc.
    Kind Regards,
    Morne
      I do a memory test in my troubleshooting, but no errors. I do keep Windows current, so I’ll check what version I’m on. Is there a known issue?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        if its not ram and video card it could be powersupply is not supplying enough power. That and also check the cpu voltage in bios. Too low voltage could cause instability, though I'm not sure if its a xeon you can't adjust that.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          Could be a million different things like what others said
          You need to share the code of blue screen and take it from there
          Huge chance this could be a memory issue, with this kind of instability and specially that you have new Mobo .. It could be a bad RAM stick
          You need to take all of them out except for 2 and see if it crashes or not
          It takes time to test but it is worth
          Honestly Dell should do better, Maingear or Origin support would be able to figure this out on phone and tell you what to do
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
            What I'm sure about is that hard drives has nothing to do with this
            Muhammed Hamed
            chaos.com
              Every blue screen i've had in 15+ years has been because of a bad stick of ram.
                I did a RAM test, which took many hours and there were no errors. I found it strange that the DELL people did no troubleshooting. No request for code, event viewer, nothing. They just want to replace parts. It is like a backyard mechanic. I'll take a photo of the blue screen when it happens again, I did the research on the code, and it was so generic, it didn't help.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  The code won't confirm if it is a RAM issue, although some codes would point you to recent windows updates or Nvidia drivers..
                  It is still possible that your BSOD is related to RAM, even though your RAM test came clean
                  some of the RAM issues are nasty, and very hard to track. Trouble-shooting should start by checking your RAM sticks 2 at a time, and see if you get crashes
                  Vray can trigger most of RAM issues btw, pick a scene that has fur or something and use it for your testing
                  Let me know how it goes
                  Muhammed Hamed
                  chaos.com
                    Here is the bkuescreen
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      I have dealt with this before, 90% chance it is your memory causing this error specially that it happens using a PS plugin
                      could also be one of your CPUs .. If you want, I can guide you through troubleshooting this
                      How frequent do you get this error? Is it random or specifically in PS?
                      Do you have steps to trigger this error? so finding out the faulty RAM stick wouldn't take time?
                      Heading to bed now, will check here tomorrow after work
                      Muhammed Hamed
                      chaos.com
                        It happens when I run PS plugins, but it also happened when I was doing something else (I forgot what it was). It doesn't matter what plugin. It happens like this. I work in MAX to create an image, usually an EXR. I open it in PS, do some color correction and then run a plugin, which will crash Windows. I'll reboot Windows (it won't' reboot by itself) and go to PS again and the same plugin will perform perfectly fine. PS won't crash every time in the order described above, but usually every 2-3 times. I have 8 sticks of RAM and they all tested file the other day. The DELL guy that came out had a hard time getting Windows to boot when he replaced the motherboard. He had to do one stick at a time and at one point he thought he found a bad stick until he put it into another slot.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          It is possible that the memory test doesn't pick the memory issue.
                          100% it is a memory issue, I had the same behavior with Adobe premiere in the past. stress testing wouldn't crash the system, it only will bluescreen occasionally in PR
                          Now we need to find a way of triggering this error, so we find the faulty stick
                          Did you crash on rendering with Vray/Corona so far? Have you tried rendering something that uses Vray fur?
                          We can try stress testing the memory with Aida 64, there is a chance we can trigger this crash. If we cannot trigger the error this way, you will take out half of your RAM.. we might get lucky and find the faulty one fast.
                          If you don't mind me asking, why did he change your motherboard?
                          And are you running windows 1903 with all updates?
                          Muhammed Hamed
                          chaos.com
                            You can download 2 awesome utilities
                            WhoCrashed - https://www.resplendence.com/whocrashed
                            and
                            BlueScreenView - https://www.nirsoft.net/utils/blue_screen_view.html
                            Both utilities will show you details of what crashed and why. Helped me to resolve a couple of issues.
                            Available for remote work.
                            My LinkedIn: https://www.linkedin.com/in/olegbudeanu/
                            • #15
                              Thank you, but both links are dead.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
