18% Gray
  • 18% Gray
    How do I make this box 18% gray in the viewport? I usually do it in photoshop, but I would like to do it with the cameras white balance. The box is 128, 128, 128.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    from the values, you can see that the image has more red and green than blue. So you need to compensate for this by doing same with cam. Making the white balance more red, will introduce more blue in the image.
    So,
    take your "98, 89, 81" from your pixel reading there, and stick that into the cams white balance. Then its a case of adjusting exposure for the brightness
    Kind Regards,
    Morne
      128 rgb in max's color swatch for diffuse of VRayMtl is 50% gray.
      trims around the windows should be white, right?
      Marcin Piotrowski
      youtube
      CGI OCIO config 04
        Put a vray color in the material diffuse and set it to 0.18 x 0.18 x 0.18.
        Then you get a representation of a real greycard with the advantage of not having reflections on it (unlike the real thing).
        But arend 18% greycards used to get the exposure right in the real world?
        They should also work for white balancing, though.
        You can put such material in the material override and use the auto white balance to get the right number in vray.
        That's even more accurate, since there will be no color bleeding from colored surfaces on your grey card/box.
        German guy, sorry for my English.
          No, trim is gray. The box is 128, 128, 128
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Both should work, though.
            I haven't had much luck with auto-exposure, but I'll try it with a gray override.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
