2D Articulated Silo People?
  • 2D Articulated Silo People?
    I'm looking for a way to easily put a 2D silhouette in a scene. I thought about vector clipart, but does anyone know of a source for something that could be articulated to match the scene and maybe even rendered in MAX? I tried working with a rigged biped which I thought was pretty slick, but the client is after something more simple like the attached. Ideas appreciated
    Dave
    David Anderson
    www.DavidAnderson.tv
    Software:
    Windows 10 Pro
    3ds Max 2023.3 Update
    V-Ray GPU 6 Update 1
    Hardware:
    Puget Systems
    TRX40 EATX
    AMD Ryzen Threadripper 3970X 32-Core 3.69GHz
    2X NVIDIA GeForce RTX 3090
    128GB RAM
    Simplest thing that occurs is a group of splines; head, torso, arms etc - very basically animated if necessary but very easy to pose anyway.
    You could also make a 'plane' person with enough segments at the joints, put some bones on him/her and skin it. That's actually probably the most straightforward.
      You could search for autocad/dwg files. Then import and you should have a reasonably clean spline to mesh/shell.
