Im going away this weekend for a break. but i need to do a ton of rendering over the weekend while im away. max/vray/backburner have been working perfectly since i built my pc.
in the past few days ive installed vray5 beta (for the Light path expressions)
yesterday i also ran windows update, to get it out of the way (its been asking me for ages, and i didnt want to risk it updating over the weekend)
after these two changes everything carried on working as normal.
yesterday, to get ahead, i queued up a load of sequences on backburner.
they started rendering fine, so i let it going and went to bed.
this morning, half the sequences are finished, the rest are flagged with errors.
if i restart any of them, i get an IMMEDIATE error about 3dsmax being unable to start.
if i start 3dsmax manually, i get a message "do you want to allow 3dsmax.exe to make changes to your computer?"
ive literally never seen this message before for 3dsmax. why is it asking now.?
i turned off UAC on my pc to remove the message.. this worked for starting max manually, but backburner still errors out if i try to run a network job.
i dont think its vray related, max doesnt even try to start.
wierd thing is, first few sequences rendered fine last night, next sequences actually did a few did a few frames each... so its not even a sudden, total failure...
if i cant fix this quickly i wont be going on holiday and ill probably get a divorce... so.. any suggetions appreciated
EDIT: ive tried rolling back the windows updates.. no change.
EDIT2: tried uninstalling vray.. no change.
