Max 2021: Substance error message before every render
  • Max 2021: Substance error message before every render
    Hey guys,
    I get an error message from the Substance plugins telling me that an incompatible renderer was found (V-Ray Next 4.3). Even if I tell it not so show up again, it shows up. Any way this can be fixed permanently?
    Yeah incredibly annoying. I ended up uninstalling.
    mekene
      Update to the latest from here:
      https://www.substance3d.com/ecosyste...ce-in-3ds-max/
      Simply, I love to put pixels together! Sounds easy right : ))
      Sketchbook-1 /Sketchbook-2 / Behance / Facebook
        Originally posted by M.Max View Post
        Does that get rid of the dialog about Substance scripts when you switch renderers? I only see that dialog when I switch renderers. It is annoying, but I don't often switch renderers once I have set one (except to use Krakatoa to save particles sometimes, which requires switching back and forth).
          Yes, it stopped showing after updating.
          I only use Vray, VrayGPU, Corona and Arnold, so I'm not sure about Krakatoa.
