Deal with Revit file iterations - and incorrect models - how?
  • Deal with Revit file iterations - and incorrect models - how?
    Hi Guys
    How do you deal with Revit file and design iterations? Is there some magic plugin, perhaps from Sini or other's that can make life easier?
    If we model things ourselves, then iteration is simple enough. But often, clients would send Revit files, that sometimes are not correctly modelled or materials have been applied incorrectly or not at all. That means it takes a bit longer to clean up in Max. Often you have to detach subobjects, pull vertices etc. This is good and well in a single design, but often the client would send a redesigned model and that of course completely invalidates any poly edits you were forced to make etc and you almost have to start from scratch again.
    Kind Regards,
    Morne
