Substance in 3ds max does not detect corona 8 renderer as primary renderer
  • Substance in 3ds max does not detect corona 8 renderer as primary renderer
    I've encountered yesterday with an issue concerning Corona 8.
    I've was working on a scene using corona in IR mode when suddenly it opened up by itself a couple of windows of material folders. As I was trying to close every window suddenly 3ds max crashed.
    I relaunched max and everything worked fine until I needed to use sbsar file from substance source.
    When I tried converting the sbsar file through " Substance to corona" a dialog pops up saying "chose a primary renderer" even though the renderer is set to corona.
    I'm using 3ds Max 2022. I checked if the issue happens also in 3ds max 2021 and 2023 and yes it does and in both I've installed corona 8.
    I've talked today with a colleague of mine that has been experiencing this same issue aswell on max 2021/2022 and 2023.
    Attached is a screenshot of what I'm experiencing.
    I hope you can resolve this issue asap.
    Thanks
    Though this is a Chaos forum, there's another forum for the Chaos Corona renderer. You will get better and faster help if you post your question there.
    Thanks,
    Vladie
    Vladimir Dragoev
    Product Specialist
    Chaos Cloud
