material conversion script.
  • material conversion script.
    hi guys, i need to do one of two things... hoping somebody has a trick.
    EITHER : change wirecolor of all objects to match diffuse swatch color in assigned material - i have "wirecolor toolbox" script, which does this, but it does not work with autodesk physical material, and the models i have are using those.
    i have contacted the author of the script, but ive not heard back, and its super urgent.
    OR: convert all physical materials in scene to architectural or standard materials, keeping diffuse colour the same. -this would allow me to use the above script.
    any suggestions? ideally i need a solution today!
    could probably be made simpler and add error checking, but this should do the job assuming all geometry has physcial materials applied:
    Code:
    obj = for o in geometry collect o
    for i = 1 to obj.count do obj[i].wirecolor = obj[i].material.base_color
    if you mean the generic autodesk material, then try this one instead:
    Code:
    for i = 1 to obj.count do obj[i].wirecolor = obj[i].material.Generic_Color
    you'll get errors if there's other types of materials in scene (somebody else can chime in with error checking or making it simpler)
    Kind Regards,
    Morne
      thanks Morne that worked a treat. i really need to learn some simple scripting.. been saying it for years.
