How to control the folds of a cardboard box using controllers/wire parameters?
  • How to control the folds of a cardboard box using controllers/wire parameters?
    I'm at the early stages of creating a client's cardboard box that is made from one sheet of cardboard but gets folded up in quite a few places.
    I want to be able to control those folds somehow and looking online for a solution it looks like this tutorial on YouTube gets close to what I'm trying to achieve;
    https://youtu.be/a7x5HvhPNeY
    However, in that tutorial the box consists of 6 or so separate planes, and so this solution looks relatively easy to do.
    My box is a lot more complex, has more folds and is made from one plane (with many edges).
    I want to control the folds at 'edge' level.
    Any ideas?
    Click image for larger version  Name:	Box-Cardboard.JPG Views:	0 Size:	80.6 KB ID:	1152454
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    It might be possible, though a bit complex to set up, using LinkedXforms.
    So for example like the attached.
    I think I tried this method on a standard tetrapak carton (for milk etc.) and it was awkward.
    At least your model is a bit more straighforward
      Bend modifiers seem to work rather well actually, as in this person's example https://www.reddit.com/r/3dsmax/comm..._made_this_as/
        Oh wow, thank you so much! I'm taking a look at your files right now (and that reddit animation looks a good way forward too!). Many thanks
        Jez
          One more solution would be to use bones. It's 'fairly' straightforward, though can be a little daunting if you haven't used them before.
          The advantage would be that you'd only have bone rotations to worry about animating, rather than many control objects (messy), or many
          bend mods, which could also be troublesome for timing etc.
            Thanks again fixeighted
            I'm struggling right now with just animating polys using the Edit Poly modifier.......(can you help?)
            Where I'm struggling is with the new working pivots in 3DS Max 2023 when using the AUTO-KEY....
            It disables the transform center and so I can't rotate a poly around an edge.....
            Any ideas?
            (sorry, I don't do this kind of thing often )
            Jez
              Man, after hours going nuts, I finally found the solution online.......
              Turn off "Local Centre during Animate" (Animation Tab in Preferences).....
              That was driving me nuts
              Jez
