Hello does anybody use one of the VG plugins? I used polygonmap for many years, recenlty switched to a new pc and need to activate the new license. Sadly no response from that guy - tried to write to support coupletimes. I even tried to buy that plugin again with no success. Just wondering maybe anybody here knows more....?
VG Plugins
When activating the latest plugins, you have to enter your email and thre rest should work automatically. However with the current situation (.RU) things may be completely different now.
If things really don't work you can always get UVTools which does the same thing although a bit more complex. Or TerrainAxe. I purchased these plugins mostly to map curved brick roads that come as a mesh from external programs.
Thanks - after entering my email and pressing the activate button it says license found but activation failed - I wrote to the autor many times - yes agree my concerns are it is russian based - sad story;( Main usage here is to map many structure beams lets say roof beams or roads, and abylity to orient the textures with the length flow, was testing UV tools, but was not able doing that with it, will have look at the terrain axle.
Look in the help file on their website (HQDetails ... also Russian!). Under "common" and "mapping" are some tools that align textures to edges either automatically or by edge (either pre- or post-pick). There are a lot of tools that can do a lot of things and you often need more tools to do one thing (like aligning texture to a curved road), but it is all there.Last edited by trick; 16-01-2023, 01:45 AM.
