chromatic aberration
  • chromatic aberration
    Are you guys still doing chromatic aberration? How are you doing it? I stopped years ago, but I might want to try it again, but I want it easy. All the PS actions I have tried way over do it. I had this, but they are not developing it anymore and all their links are dead. http://arionfx.com/arionfx-for-photoshop
    I found this, but it causes havoc in my images - https://graphicriver.net/item/3d-ren...tions/18588252
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Load a map in your physical camera and you will get CA in your renders, this way it will work properly with DOF too.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Can you elaborate?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Just load an aperture map in the physical camera.
        Here is an example with and without the map:
Name:	Screenshot 2023-02-11 alle 16.02.53.jpg
ID:	1172754 Click image for larger version
Name:	Screenshot 2023-02-11 alle 16.04.23.jpg
          I am using MAX, so I'll have to see if that is supported. I don't think it is.... Thank you!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Yes, I use this a lot in Max. It’s in the VrayPhysicalCamera settings. Bokeh Effects->BitMap Aperture.
            Note there is a bug where Depth of Field is turned off if you enable the BitmapAperture checkbox but do not load a map into the settings.
              Any resource for the map to use?
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                You can easily build it by your self in PS by layering R G B with a slight offset in additive mode, you can give any shape you want.
                  I have tried everything and I have yet to get this to work.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Make sure you have DOF turned on. You really only see it in the out of focus areas. It is not a full CA solution, but it is better than nothing. It does render a hint slower, though.
                      Maybe it is working an I just can't see it. I'll post this when it is done. THANK YOU!
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I'm working a lot for removing chromatic aberration of the pictures I take out in the nature.
                        Anyway, is there a recommendation for the resolution for the source picture? Does it have to match the rendering resolution?
                          No, even a 512pixel bitmap will do the job
                            Bobby, did you get it to work?
                            Here is a tutorial about how to do it, as well as aperture maps you can use:
                            https://youtu.be/1xz-ERMA12I
                            Chromatic aberration will only show up in your DOF though and not the focused parts of your rendering. I think the easiest way to create CA is Photoshops Lens Correction tool, but it is the same in all places in your image, not like a real cameras CA where it mostly is seen closer to the edges of the phot.
                            Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
                            www.AddYourLight.com
                            Always looking to learn, become better and serve better.
                            • #15
                              I didn't, so I'll check it out. Thank you!
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
