3ds Max - Preparing save takes forever
  • 3ds Max - Preparing save takes forever
    Has anyone run into this issue? Max 2023. Scene saved locally. No compression on save. I've run a reduce file size script. Scene isn't that big. Takes forever to save while stuck on 3% "Preparing Save"..... Driving me nuts. If anyone has a solution or two that would be much appreciated. Thanks -T
    Hi rusteberg
    Did you figure out a solution for this? I ran into the same issue, and the scene just crashes. So I can't save any new changes. Autoback crashes too...​
      I think it miiiight be max saving a thumbnail which you can turn off in preferences.
        No never did on that one, haven’t really run into since then. Maybe try what James recommended above and see if that helps. That way there’s a record of solution?
          I had the same issue yesterday. I killed MAX, and it hasn't happened again. BTW, I have to kill MAx often .
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            Yep! Happened again.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              We've definitely been struggling with this one. I think in our case it is related to RPManager use, with lots of visibility sets on lots of objects (10k-60k object count ballparks). Initial tests removing all RPMdata scene saves pretty quick, which is not a problem we've had before, been using RPM heavily for years. I also wonder if it is something else along those lines, for any non RPM users out there, like lots of custom attributes being imported from Revit FBXs or whatever the 'day1ref' lists are in track view, animation layers and those sort of things. Currently using 2023.3. I wasn't sure if it's actually taking longer, or just feels like it now having the different saving stages being displayed in status bar, versus prior to when we had that and it was just a general 'save takes a long time'.
              | LinkedIn | Twitter | JCanimator.com |
                I don't use RPManager.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Any resolution? It's a new project and the same issue. It has been siting at 3% for over an hour.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Any resolution? It's a new project and the same issue. It has been sitting at 3% for over an hour.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Screw this, I've recently been moving to Blender, no problems, and then I come back and blow the dust off of 3DS Max to use for one project and straight away I hit this dinosaur.........
                      Still no solution?
                      **** UPDATE ****
                      After around 10 minutes, mine completed saving.
                      Jez
                      3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
                      Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
                      Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
                      ---- Updated 06/09/23 -------
                        I figured this out on my end. I had the exact same issue. Here is what i did (I'm in 3ds max 2024)
                        -Saved out each layer individually in max by doing a save selected. Can also be done by saving small sections of geometry at a time.
                        -Once I got about half way through my file while performing another "save selected" of a layer with some basic geometry on it (only 4 pieces of low poly geometry) my scene stopped at 3%
                        -I did a force quite, reopened my file, found those exact same pieces and noticed they had instanced modifiers on them (shell modifier).
                        -I converted the geometry to editable mesh which will obviously collapses everything.
                        -Entire scene saved perfectly after this within 10 seconds and it's a 320 mb scene (compressed).
                        There must be something from 2023 and up where max gets weird with saving when geometry has certain instanced modifiers.
                        The reason this might be the case is I did a separate test where I opened an old exact copy of my file in 3ds max 2021 (which was last saved in 3ds max 2021) and I re-saved the scene and had zero issues saving without touching any of the geometry like I did previously when I had to collapse the pieces.
                        3ds Max user since Kinetix version 2.5
                          Hmmm…. I have an associate who loves modifiers. Stacked deep and instanced…. Gonna have a talk with that boy. Thanks for the info -T
                            This was the problem for me, thank you!
                            • #15
                              Thank you! This almost solves my problem as well. Instead of 2 min save, convert to mesh and back to poly, I can save in 5s! But as soon as I make instances of this object, the same thing happens again. I tried doing 30 instances and the save took 1m. I tried doing 30 copies instead and the save took 20s! The scene file grew from 80MB(with 30 instances) to 717MB though, so that is not an option.
                              I cannot understand how this is not resolved yet? I experienced this problem when going to Max 2022. Spent a lot of time with Autodesk support and they blamed it all on my geometry. Been using Max 2021 ever since with none of these issues. I try every new iteration of Max and same thing every time, sadly.
                              *edit. I've done a little more testing. There are a couple of groups inside of a group that I'm working on. I ungrouped everything and regrouped the same way and 30 instances now takes 20s to save. Progress! But it makes me mad because if I save the file as a 2021-scene and open it in Max 2021. It takes 2,6s to save... The exact same file!
                              *edit2. If I don't use groups I can save the 30 instances in 14s. Better, but nowhere near under 3s! And I like to keep my groups!
