time slice script
  • time slice script
    I remember a timeslice script ( or did I dream it?) does someone know where I can find it?
    thanks
    Daniel
    Daniel Westlund
    try www.scriptspot.com
    Chris Grant runs a great site over there!
    Thanks
    Mathew Everett
    http://www.lappymats.com
    Phillipians 4:13
    "I can do all things, through Christ who strengthens me."
      thanks.
      Looked at the site and everywhere but all the scripts was old. Like for max 3 etc. Guess matrix is not so hot anymore
      _Daniel
      Daniel Westlund
        might have imagined it. usually i do it manually. there was alot of chat about my methods in the beta testing forum of aura
        http://www.elfpro3d.com/anim.avi
          that was cool. It´s ok to do it manualy but I want the motionblur on everything and I dont know how to do it on particles. otherwise I cud do without Da_elf Pleace tell me how you managed.
          Daniel Westlund
            Originally posted by roppin
            thanks.
            _Daniel
            Did you try these? Chances are pretty good that the scripts will still work.
            Eric Boer
            Dev
              The scripts were for max 3 and 4 I tryed at least one without luck and some links are dead.
              Daniel Westlund
                That sucks
                here's a good tut to do it the hard way http://www.veda3d.com/edu/bullettime/tut_bullettime.htm
                Did you try Bobo's Maxtrix script, it's for 4 & 5 maybe... http://www.scriptspot.com/bobo/mxs4/maxtrix/
                Eric Boer
                Dev
                  rerender. I tryed the hardway tut without luck. Dont know, mabe I did something wrong but I´l try it some more Allso in that scen ther som movement like 30 ticks. Not much but if ur going for many frames that can be a problem. I remember from erlier max versions that you cu´d shorten the time an object was moving without having to move keys. But I cant find that bar in track view anymore.
                  Daniel Westlund
                    honestly mine didnt slow time down. it just plain stopped it. and basically its sooooo time consuming i wouldnt recomment it since it means setting up 100 cameras and setting up the 100 cameras with 100 outputs in videopost.
                      I have been playing with MaxTrix it is pretty cool, works great
                      The trick is to install it to the script directory like the instructions say but then "open" it in the script menu (not "run" ) then press "ctrl+E" (this evaluates the script) then got go to the customize and you will find it there under Bobo's tools (or something like that) , just drag it to the tool bar and Voila, works
                      Eric Boer
                      Dev
                        rerender. If I ever go to Culifornia I will by you loads of beer
                        Daniel
                        Daniel Westlund
                          It's a deal
                          I am looking forward to see what you do with it, hmm wonder if there is a chair involved, hehe
                          Eric Boer
                          Dev
                            Fortunately I was able to dig up Dagan Potters two bullet time scripts with the broken links you were referring to from an old archive I have lying around... If you want to try them, they're up now...
                            Christopher Grant
                            Director of Visualization, HMC Architects
                            Portfolio, ChristopherGrant.com
                            • #15
                              No no. I have to renew my self. This is totaly different, more flesh
                              cgrant3d, I´ll try yhem out as well, thanks
                              Daniel
                              Daniel Westlund
