624 Watts!
  • #31
    Originally posted by bruce_hart View Post
    Hey Bobby - hope the Van life thing is working out. Looks like a great view at least.
    Out of interest - with 2 x 4090 cards in your PC - how does that work in Vantage? Does it use the combined VRAM of the 2 cards or just one? Are you using an NVlink Cable?
    it show that it is seeing both cards.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #32
      Yeah, this mornings curcuit break sent everything down, so both outlets share the same breaker. My PC is on a backup, so I have 15 or so minutes to get the power back on, but yes, everything went down.
      Solar power is really over promised. My RV is an off grid package, which has solar panals on top. Not until I started using it did I realize that the only thing it does is trickle charges the battery (marine battery), and allows you to charge your phone; not much more. To get more electrical starage, enough to run the RV for a day, it'll cost around $7000. The kicker there is it takes a day to charge. The ranch has its own solar, which is where the shore power goes. Point being... solar is extremely expensive and you are still limited.
      yeah, I think to run completely off of solar power, when you're heating and cooling and running other every day stuff, you need a fairly large area of solar panels and large batteries.
      www.DanielBuck.net - www.My46Willys.com - www.33Chevy.net - www.DNSFail.com
