Rendering to SVG-format
  • Rendering to SVG-format
    I got this request to render SVG-versions too. Any idea, what would work. Copilot suggested to use "Render to Texture" -feature and then continue with a Vector graphics software.
    Copilot really is crap isn't it?
    Max can only export flat graphic elements as svg, so line drawings effectively, or filled 2d shapes.
    For anything 3d you need something (probably the only one actually) like FinalToon from Cebas.
    Illustrate will do it too but it is very old and only works up to Max 20 or 22.
      PSoft Pencil+
        What I do, is to create side and top views of my orthogonal renderings. Of course I create normal renderings with camera and perspective, but these will be used at production line graphic user interface. Currently the UI-renderings are more or less Photorealistic even without perspective..
          Ok, so what you could do if it works out to be feasible and doesn't need plugins etc., is attach all the geo and then make a slice through the lot, at whatever cross-section you like.
          Those splines can then be exported as vector, either by spline thickness or default, or even filled shapes, if you use an edit poly any closed spline.
          Must be worth a go I reckon
            Actually I have the layout as 2D-AutoCAD DWG-file. I tested to open it into Adobe Illustrator, but illustrator failed to read the file. On option would be to import the file into AI and color the areas there - a bit tedious, but doable. Then they would have it as SVG.
              You can use Rhino3D (90 day unlimited trial if you don't have a license). Then use the make2D command: https://docs.mcneel.com/rhino/mac/he...nds/make2d.htm, can be saved as an SVG / AI / DWG / ...
              Edit: unless it's a mesh, then you can't use make2D, but you can make nurbs from your geometry normally. In any case Rhino can help you with converting to other formats if you already have the drawings like you said.
              Edit2: not sure if the documentation is outdated, but this old thread (https://discourse.mcneel.com/t/make2...bjects/5134/14) says meshes are supported, just tested it and they are indeed supported, so normally you should be able to make2D on a mesh. If all else fails you can use meshtonurbs.
              A.
              www.digitaltwins.be
                I recall testing Cartoon shader in Max and then imported the rendered file into Illustrator. There I was able to export SVG, but I didn't like the results. It will go to some kind of HID (Human Interface Device) application. I might take another look into that approach.
