Hi all...
I'm quite desperate as I just installed 3dsmax8 on my system, overwriting the 3dsmax8beta (dunno if the problem has anything to do with this), and now backburner refuses to work when i try to submit a job. It just gives me following error:
"Cannot network render. Backburner not found or not installed.
Verify that the path to the Backburner is set in the windows path environment variable or that backburner is actually installed on that system"
Of course, BB3 is installed and also the Path is set - I reinstalled everything three times now, checked all path variables, if i start the server it is working and connecting to the manager, as the monitor does as well...
Any hints on that one?
Thanks a lot,
Michael
Thanks a lot,
Michael
