Measuring Cubic Volum in Max
  • Measuring Cubic Volum in Max
    Is there any possible way you can measure cubic volume in Max with closed meshes. Ex. If you want to re-grade a site and you compare the differences between the existing and the proposed.
    Thnks
    Indecisive archictects will be the death of us all.
    if you dig a spot into maxscript there is a FAQ entry in the help for "How do I calculate the Volume of an Object?" find it easy searching for 'volume'
    Run that on both meshes and subtract?
    Edit: or use the Measure utility in the Utilities panel.. forgot about that one
    Dave Buchhofer. // Vsaiwrk
