sRGB vs Adobe RGB
  • sRGB vs Adobe RGB
    Ok... this question is probably linked closely to the threads about linear color space and workflow over in the tutorials sections - but i'm posting here because its not about Vray.
    For some reason we have always worked in Adobe RGB and using a Macintosh Gamma of 1.8 in MAX, but after all the buzz about linear workflow I'm quite keen to start using the Throb's and Gijs guidelines in the tutorials section.
    My boss, however, is not convinced about working in sRGB and using a gamma of 2.2 (although all our monitors probably are using default sRGB) - he's read that sRGB has a limited gamut and doesnt print as well as Adobe RGB.
    Question is: can you still work with a Gamma of 2.2 in max and combustion and then for print projects use Adobe RGB in Photoshop or is it one or the other?
    Jonas Andersen
    Cadpeople | Visual Communication
    www.cadpeople.com
    I'm not quite versed on the issues of the linear workflow, but your boss is right about sRGB being more limited than AdobeRGB.
      sRGB is for typical televisions which can't display the same number of colors a regular monitor can - correct?
      LunarStudio Architectural Renderings
      HDRSource HDR & sIBL Libraries
      Lunarlog - LunarStudio and HDRSource Blog
        i don't think so.
        srgb was/is an attempt to find a common color space for all users, including non-professionals.
        before most consumer ink-jet printers didnt have a color profile at all, now they at least support srgb, which is limited but better than nothing
        same for most consumer monitors - dedicated color profiles are only common for very few high-priced output devices
        tv normally doesnt use srgb at all
        according to wiki, srgb was tailored to meet the typical properties of common crt monitors
        http://en.wikipedia.org/wiki/SRGB
        http://en.wikipedia.org/wiki/RGB_color_space
        bruce lindbloom suggests that the PAL TV color space is identical with srgb - except green is different
        ntsc uses different primary colors
        http://www.brucelindbloom.com/index....SpaceInfo.html
        http://ivrgwww.epfl.ch/publications/sbs99.pdf
        page 6 has a nice diagram showing different color-spaces in comparison to CIE LAB
        cu mike
        oh btw: yes, srgb has a much smaller gamut than f.e. adobe rgb or even ProPhoto rgb (which i'm using as an intermediate space for image-editing)
