Splines and model rotation
  • Splines and model rotation
    This is something that had bugged me for a long time. Maybe the answer is simple, maybe not.
    The problem is I am creating splines on a complex model - using Face snap. What I need to do is rotate the model without closing the spline ( existing spline creation mode ). At the moment I use the standard Alt MMB to Arc rotate - whenever I do this it is the same as RMB - i.e. closes the spline.
    Anybody have an idea of how I can rotate around the model while creating a spline? Sounds simple right ?
    Thanks as always for your help.
    seems to be impossible
    i even tried changing the viewport via maxscript (macroscript mapped to the keypad) but it also cancels the creation mode
    the only possible viewport movement i know is the virtual viewport's interactive pan using the keypad (first / and then 4, 8, 6, 2)
    but no rotation
      I dont know for rotation, but for panning simply hold the "i" key and you´ll have interactive panning (viewport follows your mouse)
      Thorsten
        nice tip!
        btw: i found something for rotating:
        customize keyboard, switch to the tools category
        roll viewport CCW
        roll viewport CW
        yaw viewport CCW
        yaw viewport CW
        pitch viewport down
        pitch viewport up
        you can assign those to the numpad and use them in creation mode to move around - not perfect but it works
        it rotates about the viewport center and doesn't interrupt the creation of objects
        my current key assignment:
        NumPad 7 --> Roll Viewport CCW Big
        NumPad 9 --> Roll Viewport CW Big
        NumPad 8 --> Pitch Viewport Down Big
        NumPad 2 --> Pitch Viewport Up Big
        NumPad 4 --> Yaw Viewport CCW Big
        NumPad 6 --> Yaw Viewport CW Big
        NumPad 5 --> Pan Viewport (thanks instinct!)
        works for 2-handed modelling (numpad for movement left, mouse for creation right)
        cu mike
          Here is what I do in such cases.
          Go for some general spline (closed), then add more vertexes and move them to the right snap. Thus your spline will always be closed.
          I think that with the rotating is impossible. (if Max was like the Rhino way) Could be wrong of course !
          nikki Candelero
          .:: FREE Your MINDs, LIVE Your IDEAS ::.
            It is possible with the Powernurbs Sketchtool...Autodesk should have added it since R1.2 *sigh*
              Thanks guys
              Thanks guys - glad it isn't just me who has this problem - a small thing that I will add to the wish list I think. I might mention it to discreet for 9
                I seem to remember seeing a script that allowed you to rotate and continue a spline but I looked for a few minutes and didn't find it. Maybe I'll look some more later.
                Eric Boer
                Dev
                  if you have to rebuild highpoly (cad?) meshes very often, i'd recommend looking at polyboost:
                  especially the second feature in this movie looks like its made for you
                  http://hem.bredband.net/polyboost/Po..._5_upgrade.avi
                  15Mb techsmith codec
                  look at the first feature shown here:
                  http://www.cmlcreative.com/Videos/PolyBoost2_video.avi
                  50mb
                  http://www.polyboost.com/
                  100€ per seat though
                  afaik they have a time-limited trial version so you can test it out
