MAX6 gets 100% CPU usage when left alone???
  • MAX6 gets 100% CPU usage when left alone???
    Hi All,
    I have a problem - when I leave MAX6 running for some time, without doing any modelling on it or rendering, it soon hits 100% CPU usage (3dsmax.exe process). Then I can`t move the viewports or anything, I have to restart MAX. But it repeats after some time...
    First it happened at home (XP) and now the same is at work (W2K).
    Is it a known bug? Do you have any fixes?
    I`m really going bonkers with this....
    Thx,
    http://miroslawski.net
    there was a problem a while ago with the Nvidia drivers - they caused Max to run at 100% even when you werent doing anything. If you have out of date Nvidia drivers this could be the problem.
    Win10.Ryzen1950X. 80GbRam. RTX3080.RTX2070.Sketchup 22.0.354.VRaySketchUp.6001. - NvidiaStudioDriver 527.37
      Thanks, that might be the problem, I`ll chase that issue...
      _____after some time__________
      Well, when I switch to software Zbuffer it does the same.
      What a crap!
