Ram testing
  • Ram testing
    I am having problems with my home machine that I suspect are related to ram - or bad ram. I have a boxxtech machine it is a bit long in the tooth now about 4 years but has been a good machine. It could do with a complete rebuild at some stage. The problem I have is of 3dsmax doing a hard crash when I am rendering. They are not particularly taxing frames - using scanline ( no vray at home yet ...) but I get this strange hard crash.
    I suspect is has something to do with Ram, does anybody have a suggestion on what the problem could be and where I can find a ram testing application.
    Thanks as always.
    to test your ram, try memtest. its available as an iso-version (bootable)
    http://www.memtest86.com/
    max 9 + vray
      i'd suggest memtest plus
      memtest plus - LAST VERSION : 1.65 10/01/2005
      it's a newer version based on memtest86, open sourced with better support for newer motherboards:
      http://www.memtest.org/
      they also have a version that runs off a bootable (dos) usb stick
      ps: check your ram timings
      if those are ok and you detect ram errors with memtest (plus) try to run memtest on a single module at a time
      in my case i was able to identify a faultiy ram module (brand new corsair valueram) and have both modules replaced - no problems ever since
      are you cpu temperatures ok? the coolers tend to fill up with dust after some time, reducing their efficiency a lot (also the fans tend to die after some years)
        Thanks guys
        Thanks a million I'll give a shot and also have a look inside the old beast. It has been some time since I checked the fans and cabling. It is funny, I have been useing the home machine for the internet only for the last couple of years - main macihine in work, now I'm doing more work at home and need to get things in shape - I am finding lots of problems.
        Thanks again.
