Simple Scripting question
  • Simple Scripting question
    I am exploring the wacky world of maxscript and I have a question:
    I have written a simple script that allows me to select an object and turn the visability to 0. The problems is I do not know how to get the script to close the parameters box (click OK)
    Here is the script - any advice will be much appreciated.
    $.executeAction 0 "40022" -- Edit: Properties
    max properties
    $.visibility = 0
    Thanks as always
    Viability back on
    The script seems to be working now in it's much simpler form :
    $.visibility = 0
    But when I try to use it to turn the visability back to 1 I get the following error :
    $.visibility = 1
    -- Syntax error: at keyword parameter, expected name
    -- In line: $.Edit: Properties
    I know there are some scripting nerds out there who can solve this.
    Thanks as always
      try not to use the $ when scripting: make collections of objects or arrays your working method:
      Code:
      s=selection as array
      for i=1 to s.count do(
          if s[i].visibility != undefined do(
                  s[i].visibility = 1
      That way you won't lose your selection around, but safely have it stored somehow.
      Lele
        Thank you
        Thanks a million, can't wait to see this in action. I am such a newbie to scripting but can see how it could get addictive very easily. The more I use it
        Thanks as always
          I can tell you it's almost 4 years i toy with it, and i keep discovering new ways to do things...
          It's a wonderful cross between logic and language, a damnable drug!
          Lele
            Adam,
            I can definetly recommend Bobo's maxscript DVD over at CG Academy. Well worth the money.
            -----Dwayne D. Ellis-----
