Yes, another win x64 thread
I was setting up a new machine (dual 270's with 2gb ram) and had hoped to install x64 to future proof it a little once I up'd the ram a bit. I set everything up, did a few test renders, everything was working fine with VIZ 2005 (based on Max 6). I then tried to update a DWG linked file from autocad and it bonked me. It gives an error about "MICROSOFT VISUAL C++ RUNTIME ERROR .... ABNORMAL PROGRAM TERMINATION" (I don't have the error in front of me right now). I then tried just a clean new VIZ file and tried to link a simple CAD file of a cube; same error. After a lot of searching on Autodesk's website and the net and finding nothing, I was forced to just reinstall plain XP and set everything up that way.
Can anyone else running x64 confirm this on their system? If need be I can upgrade to VIZ 2007 but probably not to MAX 8. Has anyone else on Win x64 encountered any other problems running VIZ/MAX?
Thanks,
David
Thanks,
David
