I've just gone through the process of doing a fresh install of Max8 sp3 on my home pc, but when I load it up, I get a Loading DLL error:
DLL <C:\......\3dsMax8\stdplugs\VIZWall.dlo> failed to initialize. Error code 126 - the specified module could not be found.
Any ideas what I need to do? If I just click OK it seems to go into Max OK. I recall something like this if you install Vray and the order of the plgins in plugin.ini being the wrong way around, but I haven't even installed vray yet!**
Odd.
**That's a related point: is there anyway to install Vray on a home machine as well as at my workplace? I don't want to buy another license of Vray - after all, I will not be using both machines at the same time.
Odd.
