looking for bamboo texture
  • looking for bamboo texture
    Somebody at one time shared a really cool bamboo weave texture complete with perfect opacity and displacement map. Ive searched and can't find it. Can anyone help a brutha out?
    what about a wicker caning texture? would that do?
    Needs more cowbell
      ya, wicker is a better way to describe it. bamboo wicker or something like that.
        Im certain I have a really good wicker map but I cant find it
        I will have a look when I get home later if thats not too later for you. Be about 9 hours away.
        It doesnt have a bump/opactiy map but its good enough to be able to make one easily from it.
        This may help in the mean time??
        http://olegvolk.net/gallery/various/...geViewsIndex=1
        http://www.awardlighting.com/images/...cker_Blade.jpg
        Or are you after the more diagonal crosshatched look
          Hi Percy,
          I think I found the displacement map, check your gmail.
          Dan
          Dan Brew
            thanks daniel, thats the displacement I remember. Now just need the diffuse. Ill try those other textures for now, thanks Daforce.
              No problen Percy, I found the post as well:
              http://www.chaosgroup.com/forum/phpB...d+displacement
              You could try PMing Gijs.
              Dan
              Dan Brew
                a combination of the too would be ideal.. im sure you can match up some of those high res wicker shots i linked you too ti match the displacement.. then your home and hosed .. after all.. as long as the displacement is really good.. the rest should just fall into place
                  I love it when a good plan comes together...
                  Thanks for the help guys.
                    LOL.... damn thats hilarious.
                    So it all worked out well enough then?
                      "i pity the fooool"
                      Chris Jackson
                      Shiftmedia
                      www.shiftmedia.sydney
