Cheers,
-dave
■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
Hey Clifton. Yeah the lack of 64 bit drivers for the Spyder Pro is a real pain in the arse. I mailed ColorVision back in April about this, and they insisted it was one of their top priorities and that the drivers should be available Q2 2006. Needless to say, I'm still waiting, and my Spyder Pro is gathering dust.
The Huey does look good - especially price wise, but I chose the Spyder2Pro because of it's ability to calibrate a dual monitor set-up. This woeked really well before I went the 64-bit route. As far as I'm aware, the Huey and other cheaper alternatives don't cater for dual monitors.
Well if you want the most accurate displays then you should be using 2 icc profiles as even if the 2 monitors were off the same assembly line one after the other they will most likely be different.
-dave
Cheers,
-dave
Well yes. But previously I was using a new LCD and a 4 year old, burnt out CRT, which were so vastly different that you couldn't even pretend to calibrate them the same. 2 new monitors, same size and brand, have got to be an improvement. Visually they look the same.
