I've got a project on just now that's made me rethink the way I calculate rates for my work.
I've been asked to produce two images in the style of a high class product studio photograph. The objects themselves are pretty basic, and the whole modelling, lighting, mapping and rendering shouldn't take longer than a day to produce. I'm happy charging at my normal daily rate for this as my client is only using it for a pitch to one of their clients. My question is whether I should limit the use of the images to what was agreed (a pitch) and that if the images were to be go on to be used for an advertising campaign (ie appearing in glossy magazines) I should charge a much higher rate given the end use of the images. I imagine photographers would charge $2-4k + for a studio photoshoot with the final images being used in an advertising campaign. I'm thinking this is an area that I need to get advice from a lawyer and/or marketing agent.
So my question is basically about at what point do you through out your normal rates in favour of charging for the inherant value of the image, rather than the cost of production (which in this case is very low).
What is your approach to this? Any advice ?
