computer problems
  • computer problems
    Hello,
    I have a problem with my computer. I built it last year and it have been doing good al since until today. It does not start, not even some noice like "pip" - silent death.
    I have tried out some things:
    MB indicate power with the green LED.
    shortcut of the ATX cabel - fans spinning.
    shortcut of the Powerswitch- nothing happens.
    Removed the ram, graphiccard, cd, battery(MB) - nothing happens.
    So is it the MB or CPU?
    Wouldn´t it start but with some noice if anything was broke?
    What do you think?
    CONFIG:
    ANTEC MIDITOWER SLK3000B AIR GUIDE NO POWER
    NÄTDEL 550W ANTEC TRUEPOWER II ATX12V 2.0 ATX
    ASUS A8N-SLI PREMIUM NFORCE4 GBLAN RAID ATX
    AMD ATHLON 64 X2 4400+ SOCKET 939 BOXED
    CORSAIR 2GB DDR PC3200 400MHZ 2-3-3-6
    GIGABYTE GEFORCE 6600 256MB SILENT PIPE PCI-E
    WESTERN DIGITAL RAPTOR 36.7GB 10000RPM S-ATA
    MAXTOR DIAMONDMAX 10 250GB 7200RPM S-ATA/150 16MB
    PLEXTOR DVD±R/RW PX-716A 16X DOUBLE LAYER IDE RET
    best regards, August
    This sounds very much like when my mobo died, I pressed the start up
    button, power light would come on etc, but nothing would happen, no
    beeps, nothing.
    I tried all my components in one of my other computers too see if they
    worked ok, which they did, which eventually narrowed it down to the
    mobo, replaced it and bobs your uncle.
    steve
      This souds exactly like when my antec true power 12v eps died... Mobo led was still working, also the fans, but no beep, nothing. Just try out another powersupply before changing the MB!
      Regards, Michael
      This signature is only a temporary solution
        Thank´s!
        Ok I will see what I can found in my old boxes... A new PSU would be much easier. But could it realy die like that, from one day to another and still suply the LED?
        I need some files from that comp, but it uses SATA disk and all my other boxes are IDE`s. Is there some way to connect SATA whitout SATA ready MB?
        /August
          It was the PSU, seems like thier have been a lot of mailfunctions with Antec Truepower. I bought Tagan Easycon 530W, with some realy nice and flexible cabels... This is what you turn out to after spending to much time at dedicated hardware forums...
          /August
