Centering the Pivot - Maxscript?
  • #16
    after you've dragged it in it shows up in customize ui as category 'Drag and Drop'.. from there you can add it to your quad menu (You might want to right click on the toolbar button, edit script, and see which Drag and Drop # the script is though to make it easier)
    Dave Buchhofer. // Vsaiwrk
    • #17
      awesome
      • #18
        i'm loving centerpivot on my quadmenu, woohoo
        • #19
          ok, and now the shortcut for "bridge" in polymode please.
          Jonas
          www.jonas-balzer.de
          www.shack.de
          • #20
            Tsk tsk Jonny
            1. Customize Menu
            2. customize user interface
            3. change "group" to edit poly
            4. click on bridge and set to key required or assign to quadmenu
            • #21
              ah. you've try'd it?
              for me it dind't work.
              Jonas
              www.jonas-balzer.de
              www.shack.de
              • #22
                hahah no.. one sec let me test it
                • #23
                  hmm its acting stupid.
                  will work on it tomorrow.. there must be a way to make it work.
                  • #24
                    hehehe
                    btw. for me, its one of the most importend tool in max.
                    and wan't work with shortcut.
                    edit:
                    ok, i've reached that i'v got the bridge settings on pressing the hotkey, or bridge is selected, and i can bridge the faces by clicking them. but i want select two faces, push (B), and there're connected.
                    Jonas
                    www.jonas-balzer.de
                    www.shack.de
                    • #25
                      errr.... can I join in the maxscript request queue.
                      I would like to the pivot point to centre on the origin.
                      Useful for stairs when creating arrays.
                      Geoff
                      www.EeDesign.co.uk
                      • #26
                        Geoff
                        $.pivot = [0,0,0]
                        replace the 0,0,0 with whatever coordinates you want.
                        • #27
                          thanks joconnell
                          very usefull.
                          geoff
                          www.EeDesign.co.uk
