very OT: windows 2003 server compatibility
  • very OT: windows 2003 server compatibility
    We are in the process of building a new video editing machine and for a couple of reasons (duplexing and user limits) we want to install Windows 2003 Server.
    However, we need to know if Server is compatible with our software. I am in the process of trying to contact various support companies, but does anyone have experience? We use the following software:
    After Effects 6.5 Professional
    Adobe Creative Suite CS2 (illustrator CS2, Premiere CS2, Photoshop CS2 etc etc)
    Max 8
    Vray 1.5 RCS (obviously!)
    Backburner 3
    Autodesk ADT
    Any ideas?
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
    should be no problem, tested all of them, except ADT.
    regards
    randy
    http://www.eldaco.net
      we have backburner3 manager running on win2003 server.at the same time, this server is a rendernode running 3dsmax8 sp3 and VRay 1.5
      all running fine, no problems at all !
      Marco
        Well i bought Premiere 2.0, not thinking it would'nt work! ... and it doesnt, it also doesnt load on xp64 either. Which seems a little odd considering you need a bucket load of ram..
        Natty
        http://www.rendertime.co.uk
          interesting. we're looking at buying the adobe production bundle, which i presume would ship with all the latest versions. good to know.
            natty, i have premiere pro 2 working on xp64 without problems.
            Contact yuor reseller and they should be able to help you out.
            Chris Jackson
            Shiftmedia
            www.shiftmedia.sydney
              Hey dude ...
              yeah i did and i they told me that premiere2.0 does'nt run on xp64?. did it load ok? i geuss it must of done, mine wont even instal, just disapears? and on 2003 it says that this OS isnt supported. pretty disapointing really as ive have to create a second boot on my workstation with xp2 on it, but now i cant use all my ram!..
              Natty
                thats just plain odd.
                Works fine on my 64bit workstation at work.
                What are the specs of your workstation?
                Chris Jackson
                Shiftmedia
                  hi
                  Its a dual, dual core opteron 275 8 gig of ram and xp64.. all my other 32bit apps work fine and just drop in the x86 folder?, but if you look on the adobe forum, people on there are complaining about this issue.
                  Natty
                    I must be lucky that it works!
                    Is there anything on the adobe forum saying that it will be updated for xp64 anytime soon?
                    Chris Jackson
                    Shiftmedia
                      Im still trying to find out about a 64bit update, but i worry that it wont be sometime soon
                      Natty
                        From the adobe forum ...
                        I'm in a similar position, having just upgraded from Premiere Pro 1.5 which runs fine on my Windows 2003 Server Enterprise dual-Athlon/2GB RAM/RAID 0/1 system (combined server & workstation for production and video streaming). The base system has been happily running various versions of Premiere since 2002, first with XP and then later Windows 2003.
                        I assumed that because Premiere Pro 1.5 runs on it perfectly, even though it is only supported on XP, that Premiere Pro 2 would do the same.
                        Alas, the installer stops at the first hurdle, telling me that
                        "Adobe Premiere Pro 2.0 installer is designed to run on Windows XP SP2 or higher."
                        I always understood that Windows 2003 was higher than XP, but it seems Adobe have decided not.
                        As a systems developer I can't think of anything in the codebase of Windows 2003 that would prevent Premiere from running on it, so it appears to be an arbitary decision to exclude Windows 2003.
                        I'm now looking at ways to have Windows 2003 temporarily report itself as XP to fool the installer.
                        Setting compatibility mode to XP for setup.exe doesn't work, and it can't be set for msiexec.exe because that is considered part of the operating system.
                        Natty
                          yeah its crap dude. I might do some more research into it tomorrow
                          Chris Jackson
                          Shiftmedia
