viz defaults global mat to architectural
  • viz defaults global mat to architectural
    HOW on earth do you stop viz from defaulting to architectural material type when you import new geometry? Every time I bring in new geometry, it switches the "global" mat back to architectural.
    I know this isn't a vray thing.
    I know you can change the defaults.ini file, but what is the code for the vray material?
      Try using the vrayt scene converter....i think it should work.
      -----Dwayne D. Ellis-----
        it hasn't been working since I went to 1.5... Is there an updated version?
        EDIT> actually, I just realized what you meant. The scene converter. I guess I could do that, it's more a matter of every time I bring in new geometry, (I typically model stuff in viz and sketchup and it's when I bring in the sketchup/dwg that this happens) it defaults to architectural as the type for the global material on the new geometry. If I don't apply a new mat to it right away and do a test render, of course I get the stinkin raytrace stuff. I usually keep a global material as a gray for testing.
