convert to editable poly smoothing problems
  • convert to editable poly smoothing problems
    I have a model imported from rhino with powertranslator. I set the correct mesh density, but then I need to convert it to an editable poly so I can put a shell modifier on it. But when I do so, the smoothing gets messed up and I can't get it to look good again.
    Is there a simple way to solve this?
    image before edit ploy modifier:
    http://www.aversis.be/vrayrhino/poly_01.jpg
    after edit poly:
    http://www.aversis.be/vrayrhino/poly_02.jpg
    do you need the edit poly before the shell?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      did you extract the poly from the pwnurbs, or converted it?
      Jonas
      www.jonas-balzer.de
      www.shack.de
        Adding a smooth operator on top of the stack, with a smoothing angle of 180 should probably fix that.
        I say 180 because the normals may be flipped in the model (while displaying correctly in viewport) so the smoother may or may not do the proper job.
        Set it to the max value allowed, and step back until it looks correct.
        Sorry if you thought about this implicitly
        Lele
          you shouldnt use smooth modifiers on PN models as most mesh operations mess up the vertex normals that aid a LOT in good shading. I'd suggest creating the shelling via pnurbs and then convert the PNurbs to Editable poly/mesh using the viewport display settings for tesselation control
          Thorsten
            Putting a shell modifier on top of the brep object crashes max.
            I only have powertranslator, and altough there is a shell option, I never been able to use it succesfully. I may work on a sphere or something, but not on more complex shapes. Also once you shelled it, there's no way to change the thickness or simply to remove the shelling. Usually creating a shell from a mesh is much easier than keeping everything in nurbs, that's why I try the edit poly conversion.
            So I used an edit poly modifier, didn't extract the mesh from the brep object (will try to find that option)
              Hey and suddenly the shell function does work! Great
                ha haaa i love it when that happens
                Chris Jackson
                Shiftmedia
