3D scanning at home. wow!!
  • 3D scanning at home. wow!!
    this is cool.
    http://www.cs.tu-bs.de/rob/david.html
    very interesting, it will be good to see this once they release the 360 degree add on
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      That's pretty neat, thanks for the heads up
      Eric Boer
      Dev
        I had a stint selling Roland laser scanners, and the software is indeed the key to success...
        There are plenty commercial softwares out there that do mesh reconstruction out of pointclouds and absolute coordinates, i'm extremely curious to see how this will manage without a reference system other than a 90 degree plane...
        Lele
          from what ive seen so far it can only work with horizontal passes of the lazer. it would be better to have to vertical planes and one ground plane for reference then when you use the lazer you can rotate it any way you want to get it into the little nooks and crannies
            A bit late on the old reply...but anyway.
            This software does similar stuff with a similar method. And works fairly. well.
            http://www.3dsom.com/
