Don't think you're going to find an answer on these forums. Not very many of us are using XP64, and of those that are, I doubt that any are using the particular NAS setup you're describing. (I barely even understood what you are asking about)
i also use network attached storage, the sc 101 from netgear.
i have the same problem: not able to use the drives from x64.
netgear wont release drivers.
the solution is to attach the unit via network to a 32 bit machine and attach it with a shared drive letter.
so if you have to access the drive from a 64 bit OS you will see it if you connect to the 32 bit computer.
I dont know what brand of NAS we use here at the office, but we had same issues. We got a replacement eventually that WOULD work. I think we also found that Windows server 64bit worked with the older NAS box I think. Might check into that.
Any network storage that requires additional drivers on the client computers is a baaad idea (and not suprising that drivers don't exist for XP64).
For future reference, you should buy a NAS device that serves up the files over SMB. That way any computer that can use the SMB standard (any Windows device, OSX, and most flavors of *NIX) will be able to access the files stored on the device.
