Backburner + AFX Jobs with cmdjob
  • Backburner + AFX Jobs with cmdjob
    Trying to use backburner for After FX network rendering via the command line tool described in the Max's help file.
    I can't seem to connect to the manager
    Manager settings
    managername : kdgdc02
    ip: 172.0.1.2
    subnet: 255.255.0.0
    port: 3234
    and this is the batch file I am trying to send to backburner :
    cmdjob –jobname “after effects test” –manager 172.0.1.2 -netmask 255.255.0.0 -port 3234 –taskfile c:\tasklist.txt –taskname 1 c:\aerender.exe –project c:\NetRenderTest.aep –comp “comp1” –s %tp2 –e %tp3
    *those are not the paths for the files i just shortened them to c:\ for this post to make debuging easier
    Always get :
    error:could not find manager
    I even got this message with this simple line :
    cmdjob –jobname “Test” –manager 172.0.1.2 -netmask 255.255.0.0 -port 3234
    I even try cmdjob –jobname “Test” –manager kdgdc02
    Any ideas of what i'm doing wrong?
    Can anyone test only that simple command:
    cmdjob –jobname “test” –manager managername
    I think the netmask is the problem... by default backburner netmask is 255.255.255.0
    Please Help !
    I post the same question here :
    http://forums.cgsociety.org/showthread.php?f=6&t=471039
    Best regards.
    My Flickr
    Please Help...
    Best regards.
    My Flickr
      Been a while since I have done it, but as I remember you need to make a connection to the manager before sending the job
      Eric Boer
      Dev
        Ok but how ?
        There is nothing in the help file.
        My Flickr
          Have you tried one of these?
          m.connect #manual "manager" -- connects to manager of name "manager"
          or
          m.connect #manual "192.168.0.1" -- connects to manager of IP 192.168.0.1
          or
          m.connect #automatic "255.255.255.0" port:1234
          Eric Boer
          Dev
            <Interface>GetManager()
            In order to access network rendering through MAXScript, you need to create a manager instance.
            The syntax is the following:
            NetRender.GetManager()
            Eric Boer
            Dev
              cmdjob is supposed to do that automatically. You said you shortened the paths. they are supposed to be in quotes tho, are they in the original command ?
              On another note those IPs and netmasks look odd to me (wich doesnt mean they cant be :P)
              Then the taskfile parameter is supposed to be -tasklist instead...that's a typo in the ae example. read a bit above in the reference.
              Just some ideas,
              Thorsten
                It's not a maxscrit it's a "DOS" command...
                Best regards...
                My Flickr
                  Just some ideas,
                  Thorsten
                  I even try this simple command :
                  and the dos prompt return :
                  May anyone try to lauch this simple command to tell me if it's work or not ???
                  As I say I think it's the submask, but I need someone to try...
                  Best regards.
                  My Flickr
                    Best regards...
                    oops sorry, had just woke up and confused it with a net job , I'll see if I have time to try it when i get to work
                    Eric Boer
                    Dev
                      well it does work here. I know cause we're using backburner to do netrendering with nuke. But we are on standard IP ranges (192.168.13.x) as well as standard subnetmask (255.255.255.0)
                      Regards,
                      Thorsten
                        Regards,
                        Thorsten
                        Thanks...
                        My first thought was the subnetmask...
                        Because we use 255.255.0.0
                        And I thing command is not able to switch from default...
                        Can anyone else test this simple command (dos prompt)
                        cmdjob –jobname “Test” –manager managername...
                        And see if it's connectig to the manager...
                        BEst regards...
                        My Flickr
                          Works here subnet 255.255.255.0
                          Eric Boer
                          Dev
                            Just sent one with your netmask (255.255.0.0) and it worked too, I think you are right that it is not switching
                            Eric Boer
                            Dev
                            • #15
                              The -subnet seems to doen't work...
                              We have to switch to the original subnet 255.255.255.0
                              We make some test, and I'll post the result...
                              Best regards...
                              My Flickr
