can't start 3ds max 8 after hang up
  • can't start 3ds max 8 after hang up
    hi all
    I need HELP!!!!
    after a hang up I can't start my 3ds max 8 again. It is loading all plugins and then nothing happens...! any ideas what's going up here?
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    a shot in the dark...
    change the graphics mode.
    hope u sort it out...
    Nuno de Castro
    www.ene-digital.com
    nuno@ene-digital.com
    00351 917593145
      this doesn't help, cause the window doesn't appears...!
      it's so strange.
      Pixelschmiede GmbH
        prob a stupid question but have to tried to reboot the PC yet? Or DONT delete but rename the 3dsmax.ini file to something like 3dsmax.ini.old and see if it comes up after rebuilding the ini file...
        -dave
        Cheers,
        -dave
        â–  ASUS ROG STRIX X399-E - 1950X â–  ASUS ROG STRIX X399-E - 2990WX â–  ASUS PRIME X399 - 2990WX â–  GIGABYTE AORUS X399 - 2990WX â–  ASUS Maximus Extreme XI with i9-9900k â–
          just do it from the sart>programs>autodesk>change display mode
          Nuno de Castro
          www.ene-digital.com
          00351 917593145
            Backup a copy of your 3dsmax.ini and delete it - max will make a new copy when you start it and might come up again.
              thanks, but YES I have rebooted. and I did this thing with the 3dsmax.ini, nothing helped.
              best regards
              themaxxer
              Pixelschmiede GmbH
                did you try changing a shortcut to say "D:\3dsMax8\3dsmax.exe -h" of course with the right path?
                the "-h" will allow you to change the graphics mode before max starts all the way.
                Eric Boer
                Dev
                  Maybe move all of the plugins out of your plugins folder and see if it boots up - might be something in there causing the problem. otherwise it's a reinstall of max :/
                    as a test you can try with a default UI config file (from a working machine or from a backup, I mean) sometimes it solves this kind of issues (I know it seems stupid )
                    obiously, in this way, you lose your custom setup, be careful!
                    a.
                    Alessandro
                      thanks for all ideas.
                      nothing helped. I have no clue what's ging on here. i will install the system from scratch. have no other chance to get it to work.
                      have a nice weekend guys. i will enjoy it.
                      best regards
                      themaxxer
                      Pixelschmiede GmbH
                        from google:
                        "all you need to do is exit max, go to the directory
                        C:\Documents and Settings\All Users\Application Data\Macrovision\SafeCast\Product Licenses
                        delete the .dat files there and restart max, now authorize it afresh and voila!! "
                        hope it works
                        Tom
                        Accept that some days you are the pigeon, and some days you are the statue.
