Do not Click! Warning::Addictive!
    47.6, tough competition around here.
      44.4m
      damn it... lost 15mins to that game
        47.1 here...
        Nicolau Pais www.id3d.pt
        My current hardware setup: HP Z820 32-Core Dual E5-2670 128GB RAM - NVIDIA® RTX 3060
          Sooooooooo addictive.................
          48.7m.
          Anyone managed 50 yet?
            Nah! still trying to fix the damned dilithium crystals isomatrix chamber on my craft, am stuck on 46.7
            • #21
              Damn it...............paper cut!
              • #22
                Originally posted by studioDIM
                47.1, third plane type.
                It's mostly in the launch though.
                Lele
                I agree
                I would be willing to bet that any type or option can make it just as far as any others (mathematically) as long as the launch is correct for the options selected.
                • #23
                  I knew some one would bust out the slide-rule eventually...
                  • #24
                    Lele
                    I agree
                    I would lean towards the third type too, in my extensive experience (about 30 years ago) with real paper airplanes the third type is closest to the type I found most successful.
                    Try 3rd type weight 0-5
                    flaps 10-25
                    and add airfoils for stability
                    Launch at a downward angle
                    with this setup I can do a loop and still get 25m :P
                    Eric Boer
                    Dev
                    • #25
                      damn it, ive gotten 48.9 many times now and just cant seem to get 50
                      • #26
                        Same thing for me 48.9m.
                        I'm suspecting that there's an upper limit there.
                        I find that zero paper weight is the best. Also throwing downwards so that the plane just skims the ground and comes up. Also global subdivs multiplier around 2.0.
                        • #27
                          Laurent
                          • #28
                            I have hit the 49.1!!!!!!!!!!
                            May be 50 is possible
                            Laurent
                            • #29
                              do you get extra points for doing a loop de loop and hitting the guy in the back of the head?
                              • #30
                                nope LOL
                                Laurent
