CS3 Extended details
Tags: None
It appears you can paint on a 3ds format - it probably works similar to something like Deep Paint. Perhaps it will only work on bitmaps.The formats it supports are:
"Photoshop Extended supports common 3D interchange formats, including 3DS, OBJ, U3D, KMZ, and COLLADA, so you can import, view, and interact with most 3D models."
The other thing which I have read is that the new CS3 will NOT be 64-bit. Correct me if I am wrong, but I've read that somewhere and have yet to prove this contrary.
