MAX 7 cannot access modifier menu anymore...???
  • MAX 7 cannot access modifier menu anymore...???
    Hi all,
    suddenly my MAX 7 got corrupted somehow.
    Anytime I try to pull down the modifiers menu (once I selected an object), MAX freezes for a minute or so, then comes back, but no menu.
    This happens with any scene, even a blank one (default).
    I "repair" the installation, from Windows add/remove software; I "repair" from the MAX7 disk; I un-installed and re-installed the software...Nothing to do.
    Any idea?
    thank you
    regards
    Gio
    Odd. Have you swapped graphics drivers?
    Try launching Max with software display drivers and see if there is any change.
    Kind Regards,
    Richard Birket
    http://www.blinkimage.com
      When you uninstalled did you make sure the directory was completely emptied?
      I believe max would leave 3rd party plugins, etc in those folders and if there is something corrupted there it would continue with a fresh install if the directory wasn't cleared out. Something to check anyway.
      | LinkedIn | Twitter | JCanimator.com |
        have you tried installing any service pack?
        -Peter
          Thank you guys,
          actually yes, reinstalling in the old folcer would not work.
          I had to rename the corrupted folder, and reinstall a fresh one.
          The new one works fine.
          Thank you
          regards
          gio
            Next time try deleting your 3dsmax.ini file first before going through the pains of reinstalling. That fixes 90% of Max UI problems.
