Ok....The two tries have failed for the card working in the Dell P690. We are having issues finding a power supply that has all the connectors plus two 6 pin PCIe wires AND the 20 pin power adapter PLUS the 24 pin adapter. Any suggestions are helpful
8800 power supply ???
Well it shouldnt be that hard at all. I have a thermalright 680w. But almost any thermalright/antec/enermax over 500w should be enough. Depends what your running tho.
I will be buying a new one soon as with all my HDD's plugged in and in the middle of an intense game often the computer will just turn off.
sorry to jump in on this. my dual xeon on a supermicro server board has a trupower antek 550w power supply, and everytime i try to stick in a firewire card it doesnt want to boot. ive tried both slots with the same result so im not sure its an irq problem. do you think my power suply isnt strong enough or something?
Well....It seems like the 8800 is the best card for the buck....BUT.....my IT guys are a little waery on trying other power supplies at this point. Cause the board is friend now....Of course Dell will be here tomorrow to give us a new power and motherboard....But then we are back to square one again. XFX said I could just plug ONE 6 pin in....BUT I would not be getting the performance.....But the other option we have is to get adapters for the 4 pin connectors to 6 pin connectors and then hook that up....But the voltage difference is what we were worried about. It seems very odd that plugging in a new power supply would fry the board....But they could have been DOA to begin with.
Originally posted by EricCamperHmmmm..That's weird.....But I didn't think the fireware cards pulled THAT much power..... Could be the irq thingy....
Extra 20 pin connector?!? That doesn't sound right. Most Connectors now are 20+4 connectors to the main - you can plug the 24 into a 20 slot - the 4 should overlap - or just go with the 24pin to 24 pin. The board perhaps gives you the 'option' between the two - better look up that motherboard manual. But having to connect two mains to one board - I'm not aware of that. Perhaps someone else that's built a dual-quad can chime in on this by looking inside their case.
This type of 850 Watt PSU should work for you:
http://www.thermaltake.com/product/P...0131/w0131.asp
I wonder how the board blew - hope he didnt try connecting two PSUs to one motherboard...
Just double-checked - even Thermaltake's beafiest PSU doesn't have an additional 20 pin connector. No offense, but it doesn't sound like your tech guy knows what he's doing.
Hmmm..THen perhaps the Dell guy told us wrong...But when we opened the case, BOTH plugs were plugged in. The 20 pin goes to the Quad Cores themselves...Or so the Dell guy says. That's the only reason we plugged both in.....HmmmmmSo confused...I shall check out the thermal
Here is the Dell PS H750P-00
Power Supply
Motherboard
Wow - that's a first for me. Sorry if I insulted your tech guy.
Are you just looking for another PCI-E connector for Dual GPUs? I think I've seen the old molex to PCI-E power adaptors.
any psu worth its salt will have atleast 2 of those 6 pin connector so enough for 1 8800gtx. and alot of the newer psus have 4,
when you got the pc from dell i assume it was working fine with both powers plugged in?
in your pic with the dell psu the 20 pin doesnt look like a normal 20pin power plug as it should have the sam colored wires as the 24 just 4 kerr wires. that is a little odd. dell proprietry crap strikes again???
haha....No insult taken my friend.....Rob is on the phone with the Dell dude now.....Basically going thru the motions of what we already know....damn the Dell monopoly...LOL.... Yeah....after we get the new mothboard.....I want the tech dudes to try another PS perhaps by Thermaltake or whatever. Of course if I had ordered the 1000PSU from Dell to begin with....It would have had the other connectors.....DOH.....
Yeah...It was working fine....But the FIRST PS we ordered...smoked a little and smelled like burnt chicken and rubber....And then the second did nothing...Weird...
