Originally posted by Franx
View Post
leasing or not, your opinions????
Building your own is pretty straight forward, although daunting the first time.
1. Buy a quality case, that is quiet - these are great cases. http://www.fractal-design.com/?view=...tegory=2&prod=
2. Decide which CPU you want (i7 is a good choice and available in 6-core now)
3. Get a motherboard suitable for the chosen CPU (I like Gigabyte, but others are just as good)
4. Get a cooler for the CPU
5. Buy a good power supply (scrimping here will not doubt result in BSOD and untold misery) Corsair make excellent ones.
6. Buy as much RAM as you can, normally in dual or triple kits, depending on MB spec. It is still dirt cheap so buy loads.
7. Stick in a graphics card, don't bother with quadros or the like, unless you're heavily into CAD apps, but even then it's probably not worth it.
8. Stick in one or more Hard Disks (depending on whether you are using RAID or not) and a CD/DVD reader/writer.
9. All the above components fit into easily recognised corresponding slots/cables on the mother board, so if you've ever played with LEGO or done a jigsaw you are qualified to stick the bits in...carefully
10 Turn it in on (fingers cross it POSTS - if not check you seated the RAM properly) and then install Windows. Win7 is a breeze to install compared to previous versions.
First one should take you a very enjoyable half a day.Simon
I need a new signature
Max2017.1 | Vray 3.70.01| win11
ASUS Z790PLUS | i9 13900K | 64Gb RAM | Geforce GTX4070Ti
@Simon
Thanks for the checklist and info, it is a big help...I am comfortable adding drives/cards/etc. even power supplies (now) but have always been intimidated to try it from scratch!
So far, I am leaning more and more toward trying my own build, as the pros for leasing are falling far behind ATM.
As far as RAM is concerned, does ECC/non-ECC matter that much? I've never really gotten a straight answer on this...
Thanks again to everyone for all the helpful comments!
Yes ECC matter. They do help they do protect ur files. But at the end u can find a way to not have to use them and still be fine.
As to case - DO noy buy any "Silent" crap cases. At the end u will have to take off ur side and blow fan 100% on cpu to just coll it down ! Get xigmatec elysium and stick as many fans as u want at 140/120mm + 1k RPM. U wont hear a thing and it will be coll(I dunno how is it coll or cool lol)
ECC and NON ECC OC that same. It's the size of bank and price thats different. I had ECC-REG in past still has them. B4 u buy ram make sure ur mother board (EVGA - since they cover in warranty Overclocking etc etc) can use ECC + CPU. i7 cant use ECC as far as I remember.
B4 u start buying pick ur motherboard, and then check vendor certified list of hardware that u can use with this motherboard...
Thanks, bye.
ECC is mainly used on SERVERS. I don't think the extra cost for ECC is worth it for a workstation as I don't see it making that much difference on a workstation.
As for the "silent" cases. They all start out like that, but run it for couple of months and it will sound just like any other case, due to dust buildup on the fans due to static etc.
You'll have to take apart the fans and wash it nicely every 2 or 3 months to keep that supposedly "silent" feel or sound
If you want to keep things cool, sticking in more fans will make it more noisy. Maybe try liquid coolingLast edited by Morne; 19-03-2012, 11:20 PM.Kind Regards,
Morne
Originally posted by MEnoMonki View PostECC is mainly used on SERVERS. I don't think the extra cost for ECC is worth it for a workstation as I don't see it making that much difference on a workstation.
The problem with silent cases is that they have very bad airflow and very little fanse - I know I did had 2 of them in past. At the end u just end up taking all apart so that cpu can actually get some fresh air to coll down components...
ECC matters - all the corrupted save errors, crashes, etc etc dont happen as often on ECC reg as it does on non-ecc reg...
Originally posted by DADAL View PostECC matters - all the corrupted save errors, crashes, etc etc dont happen as often on ECC reg as it does on non-ecc reg...
But maybe I've just been lucky.Kind Regards,
Morne
@DADAL and Morne,
Thanks guys, this is great! I was actually planning to go liquid cooling, as even my one's fans eventually become noisy, and cleaning fans is a PITA.
LOL, I also have had to take side panel off case some times...
I have a cosmos case now that I really like...http://www.coolermaster-usa.com/prod...roduct_id=2700
I was thinking of getting another, but they do seem pricey and i'm not sure if they can take liquid cooling system...
I think I will go for non-ECC since this won't be a server...I also save incrementally.
Thanks again
@Franx,
Well I like the Corsair 600T so far, but they all seem good, this is actually part of the building that I am least certain about what is most important.
Is it just price and looks, or is aluminum better than plastic for any reason?
Also liking the Silverstone PS07...
Thanks for both suggestions
My current case is an Antec case. People raved about it in the reviews as being super silent etc etc. It has aluminium panels and all the bells and whistles. You can manually adjust fan speeds on low, medium or fast. It has 3 fans. I must say that on low when I just built that system, it was "silent"(ish). But I was paranoid about heat so set it to medium. It's been a while and I got tired of cleaning the fans. Now it sounds pretty much like any other case. My cheapo Coolermaster case has a lot of perforations on top and on the side panels and only 1 fan, and I never cleaned it and it is way more silent than my expensive Antec case.Last edited by Morne; 20-03-2012, 05:45 AM.Kind Regards,
Morne
Thanks for the insight Morne.
For non-performance reasons, I am mostly concerned with:
-Noise
-Liquid cooling compatibility
-As few fans as possible
-Ease of cleaning
One of mine has the large fan on the side panel and it gets dirty very quickly...cleaned more times than can recall.
The other one (Cosmos) has little visible openings in the case and is still quite clean inside...never cleaned yet.
-Noise
-Ease of cleaning
As far as fans are concerned, I tend to favor as many as possibleand good airflow, especially if you do a lot of rendering. I think I have 9 total in my Silverstone case. Keep in mind that fan noise is not additive. Every fan you put in a box will only add around 3 db (per fan). So it would basically be as noisy as your loudest fan is. And about ease of cleaning, well once the case is loaded with components and cables, it becomes a hassle to clean, no matter what. The only thing I can see to make that task easier is to have some huge case, like the Enermax Fulmo or Corsair 800D.
