max, keyframes
  • max, keyframes
    is there a way to strech out keyframes in max? (if you made a animation with a lot of keyframes, how can i make it go slower/faster?) hope this make sense
    Yes, there is. use the curve editor.
      ah..you clever man thanx
        ah, was nothing..
          Also in the time slider at the bottom, if you highlight the keys you want to alter there is a bar running the length of your selection apears below them with a node on either end. draging either node will increase/decrease the number of frames between keys also.
          -dave
          Cheers,
          -dave
          ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
            You can also re-scale time!
            Next week : Cat skinning, a beginners guide.
            MDI Digital
            moonjam
              and lets not forget the ease curve - lets you apply an override curve on your keyframe track which you can then adjust with new bezier points/curves - kinda weird but fun
