RandomSelect Script ERROR???
  • RandomSelect Script ERROR???
    Trying to run the BlurScript called RandomSelect in Max 8 and getting an error -- Type error: Call needs function or class, got: undefined.
    Anyone know what the deal is or can point me to a script that randomly selects objects in a scene?
    Thanks in advance,
    Brian
    Code:
    percentage = 50
    for i = 1 to (geometry.count*percentage/100) do
    randomnumber = random 1 geometry.count
    selectmore geometry[randomnumber]
    a quick one to work on geometry. change the percentage according to your needs.
    Code:
    myobjects = #()
    percentage = 50
    for i = 1 to ($.count*percentage/100) do
    randomnumber = random 1 $.count
    append myobjects $[randomnumber]
    select myobjects
    This one takes your selection. Change percentage value accordingly.
    enjoy.
    Michael
    This signature is only a temporary solution
      Code:
      try (destroydialog rndm) catch()
      rollout rndm "random select"
      	spinner percentage "percentage" range:[0,100,50] type:#integer
      	button selectit "select"
      	on selectit pressed do
      		objs = $ as array
      		newsel = #()
      		for i = 1 to (objs.count*percentage.value/100) do
      			n = random 1 objs.count
      			append newsel objs[n]
      			deleteitem objs n
      		select newsel
      		destroydialog rndm
      createDialog rndm 130 50
      something more userfriendly
        ok - now it's really finished, but just one other nice approach
        Code:
           local objs = $ as array
           slider percentage "percentage" range:[1,22,12] type:#integer
           on percentage changed value do
              newsel = #()
              for i = 1 to (objs.count*percentage.value^2/100) do
              select newsel
        createDialog rndm 500 60
          THANKS!!
          Michael,
          THANKS A BUNCH!!!! I tried the first two and they work like a charm
          The other two polished versions you posted later give me a -- Type error: DestroyDialog requires Rollout Class, got: undefined. By NO means am I complaining just don't want your hard work go to waste!! You need to get these posted on ScriptSpot or added to the BlurScripts page. I searched for a while, since I have no script writing skills , and could not find anything. Hopefully I'm not messing anything up on my end...
          THANKS AGAIN!!!!!!!!!!!!!!
            well'they're far from beeing worth to be posted on scriptspot... glad i could help, edited the last two so that they should work now too!
            best regards,
            michael
              THANKS
              now it says -- Unable to convert: undefined to type: Array
              Hopefully I'm not wearing out my welcome...
              THANKS AGAIN FOR HELPING ME OUT!!!
                You need to select the objects first, should have said that! The scripts will then remove objects from the selection.
                best regards,
                Michael
                  OOPS
                  Knew I was going to screw something simple up on my end!!
                  WORKS PERFECT!!!
