Linking particles to objects...
  • Linking particles to objects...
    Pretty self explanatory really, Ive got a series of objects (a massive amount of cubes making up a shape), and I want to spawn particles and link one particle to each object.
    I can use particle flow a bit (enough to do what I want), but simply getting the distribution of the particles right to start with is going well over my head, anything I try simply doesnt work, I dont know if i'm putting the scripts in the right place or even if theyre correct.
    Found this one on CG talk which a lot of people said worked very well, but its not doing shit and ive tried running it from everywhere it lets me run a script.
    Code:
    on ChannelsUsed pCont do
    pCont.useAge = true
    pCont.useTM = true
    pCont.useShape = true
    on Init pCont do
    global ChunksArray = $frag_* as array
    on Proceed pCont do
    t = pCont.getTimeStart() as float
    if t < 0 do
    &#40;
    NumChunks = ChunksArray.count
    for i = 1 to NumChunks do
    &#40;
    pCont.AddParticle&#40;&#41;
    pCont.particleIndex = pCont.NumParticles&#40;&#41;
    pCont.particleAge = 0
    pCont.particleTM = ChunksArray.transform
    pCont.particleShape = ChunksArray&#91;i&#93;.mesh
    &#41;
    &#41;
    &#41;
    on Release pCont do
    &#40;
    &#41;
    Any ideas as to what i'm doing wrong?
    I wouldve thought this would be a fairly easy thing to do, given how common it should be.
    Well, ive got the generation working, but ive got another problem...
    My particles assign to the objects fine, theyre in the correct positions, but when I display the object that theyre attached to theyre all twice the distance they should be from a center point which shouldnt even be being used anymore...
    Here's an screen to show what I mean:
    Yellow = the particle objects, coloured ones are my original fragments. The particles themselves sit on the pivot point of the original objects.
    Any ideas?
    edit: fixed it with a workaround, shape instanced a new box the same size and it went to the correct position. Wouldnt have worked if I wasnt using cubes though...
    edit2: If you happen to be in a similar situation - reset the xform on your selected objects
