VPN and 64
  • VPN and 64
    I am running XP 64 and I can no longer VPN using Cisco. I tried logmein, but it isn't working for me.... When I login using logmein I see MAX, but my stage is my desktop, which is odd. What are you guys using to remotely access your machines under XP 64?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    im using vnc
      VNC
      are you tunneling through a firewall?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        hmm. nope
          I am using logmein on xp64 at work with no problems at all!
            Logmein
            MAX 64 and XP 64?
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              if your seeing your desktop, its because its not showing the proper video hardware accelaration. I have seen the same in VNC as well. And you need the video hook driver installed... or was it uninstalled.. cant recall.
              It could be similar with that software. Its not your firewall thats doing it. As you HAVE the connection. Its something odd in the software.
