how to prepare sky photograph to use in max env slot?
  • how to prepare sky photograph to use in max env slot?
    Is there any plugin for photoshop to create from normal photograph of sky the one that can be used in max environment with spherical nevrionment coordinates? I was trying Richard Rosenman plugin for pinching but it doesn't work for env mapping.
    Luke Szeflinski
    :: www.lukx.com cgi
    hi lukx
    i think there's a filter in PS called Polar-Coordinates or the like, dunno have the german version here. try that.
    greez
    ale
    ____________________________
    www.indivizuals.ch
      polar coordinates in PS... but this is not the best solution , helps sometimes only depends on map kind itc..
      greetz
      czaps
      ...be yourself...
        What ever you do its gonna look fairly crappy as there will be alot of pinching in the center unless your prepare for alot of manual work.
